Headphone pre-cueing sound distortion/degradation
i just bought this djay pro for mac , I’m having issues with the cue settings , can’t get it to sound in the right channels , i called numark and they couldn’t help me
i have the same problem but just wait a while and it will work again but it does sound horrible through the headphones in the minutes that it does not work
I would also really like a solution for this, because as for now it’s really annoying. I am betting it is a software issue, because it works fine in rekordbox
Hello, I’m from Argentina, I’ve had the same problem, i re-installed the driver and I solved it. I wish you luck. Regards!
