I agree Ervic, the DDJ-400 with djay would be my ideal setup if this issue was addressed. I was so beyond disappointed (and embarrassed) when this dropout issue started happening on gigs. I gig frequently and havenāt used a laptop in years. Djay on the iPad is the best solution out there for me in my opinion and the DDJ-400 doesnāt feel like a toy as so many cheaper controllers do. Hopefully this issue will be addressed with an update!
Mine failed with automix 1.5 hours in but I was using automix within the regular 2 deck interface so the mix controls were being used. I was also using a brand new Apple USB to Lightning cable and power supply.
Look, I already have the DDJ 400 and Iām spinning ok in my Mac Mini (DJay Pro 2) and iPhone 11 (DJay Pro)⦠both without any problems mixing for hours. I am considering an iPad because I donāt wanna use my phone (screen is quite small and someone can call me)ā¦
Iāve had the same issue with the new DDJ-400s. I also use the Apple USB-C Digital AV Multiport Adapter with the latest software updates on second generation iPad Pro with iPad OS. Is this a software or a hardware issue? As soon as the audio signal stops working. Audio can be heard from the iPad itself when the USB-C plug is disconnected from the iPad.
Exactly the same issue tonight after around 90 minutes, sound completely cut out. Iām on the latest Pioneer DDJ-400 firmware and using an official apple lightning to USB 3 adapter on a new 2019 iPad Air. I was hoping to use this set up for a radio show I have coming up, but canāt afford for this to happen.
I was just wondering if this is only happening when having the controller plugged in to a usb hub that is then plugged in to the Apple lightning to USB3 adapter and then playing songs from an external flash drive as that is what I am doing. Doesnāt seem to do it when the controller is directly plugged in to the lightning to USB3 adapter, or at least it didnāt with me.
Thatās strange then as itās done it on random intervals with me, and twice in automix after around 60 minutes or so. I then removed my powered hub and used it direct with the apple adapter and left it in automix for around 4 hours with no issue.
