Roland DJ-808 support?
Please make this happen! DJ-808 mapping is critical!
I really really need this to work with my dj 808!!! Pleaaaaase
please someone map this asap
Any updates on this???
Good and thanks keep it up
you can midi mapp the controller in 3-4 hours, no problem…
Truls, i mapped my old Xone Dx, which don’t have touch sensitive Jogs. I played for an hour with different setups but at the end i find what i was loking for. You find what you want, just take a deep breath and time :wink:
please do that :slight_smile:
I third that request.
I’m waiting for you (algoriddim) to upload the controller mapping to buy the Roland DJ-202, I really like your platform to have to change it because of a new controller. How much longer will I have to wait?
amigos alguien ya pudo hacer el mapping del Roland dj 808¿
Did you manage to do this? And can you share your midi map settings?
I made some mapping for the DJ808
https://www.dropbox.com/s/2l3mb7o3fuk…
To set a hot cue, hit SHIFT+pad
To jump to a hot cue, just hit the pad
I used the BEAT rotary as a dry/wet knob for FX1
Somehow you have to hit the CUE button twice to monitor the decks (as pre-cueing device i set my laptop headphone in Preferences)
It’s a start
Please release mapping for roland 202/505/808! Thanks!
Queremos los mappeos para roland. Tengo una dj808 y no la cambio por nada.
I think its very very unlikely, and they don’t need to, you can use the 8 sounds from the sampler (32 if you count the 4 banks) and 4 (12 if you count the choices for the different sounds) for a total of 12 samples running simultaneously. The reason why it’s not Roland’s plan is because the right top of the mixer is the volume sliders for the 4 sounds you have, if they make it 8 that will just make the trs a little awkward and also render the volume sliders useless. This is what people have been constantly asking for in the roland dj group on fb and the answers Roland has been giving.
[Showbox jiofi.local.html tplinklogin](https://showbox.bio/ https://jfi.uno/jiofilocalhtml https://adminlogin.co/tplinklogin/)
