Did not work…and it is not a wifi issue or connectivity as you are mentioning. It is The Login with Facebook feature…if you created an account with Facebook it will no longer work to sign in. You would have to create a new account with a Spotify Login Subsribe again to Premium and Spotify will kindly transfer all playlists and saves songs etc.
Same Here. No Need For A Refund Because I use this software Daily…practing mix sessions at Home
Any word on this getting fixed?
Man you need to fix this quickly bro
