Recording and DJing on iPad with controller
4
310
March 2, 2024
Keep pressing effects buttons to keep active. A way to disable it?
6
519
March 13, 2022
Is this Possible? Daw like set programing?
3
373
March 11, 2023
Automix Starts Transition Too Soon…
11
955
April 2, 2022
Video via AirPlay?
5
1062
March 3, 2023
Ddj 400 with iPad Pro using Djay pro
11
1117
February 25, 2023
Play Tiny Key 25 on Djay Pro
2
307
March 27, 2022
Mac Midi Mapping Location
4
829
March 25, 2022
Apple Music with djay on 2021 MacBook Pro
12
747
February 20, 2022
Save Loop MIDI command
2
334
February 17, 2022
Use multi processor cores
6
655
February 16, 2022
Waveforms fading in and out on ipad pro
8
345
February 17, 2023
Hi all !. Recently come to Djay subscription and a DDJ-400 and was using Rekordbox, have some questions, please
5
1140
February 14, 2023
Beta Program for iOS or macOS
2
330
March 16, 2022
Tidal not showing on Library in older version of djay
4
1052
February 18, 2022
DJ Pro 2 vs DJ Pro AI and new MacOS
4
1054
March 12, 2022
Transferring Cue points between streamed and downloaded songs
5
1404
February 10, 2023
some questions about djay pro and ipad pro
6
695
March 12, 2022
how to backup media library
2
1288
February 7, 2022
Using a iPad pro with a Midi Controller and External Hard Drive and Charging the ipad.
5
1154
March 6, 2022
Autoloop is 3-6-12-24 , I can’t change
2
293
February 3, 2023
Create playlist from Tidal?
6
622
February 1, 2023
Windows 10: Automix does not automatically adjust BPM after mix?
2
321
January 28, 2023
Split Cue Monitoring Switch
6
1134
January 28, 2023
Playlists on Android - Format ?
6
1790
January 28, 2023
Does djay pro ai work with ddj rev 7
2
1137
January 26, 2022
Using 3rd Party LOOP SAMPLE PACKS inside the LOOPER feature of DJAY PRO AI
2
1949
January 28, 2022
Which controller to choose?
13
1444
January 26, 2023
Dj Pro AI: video mixing on projector issue
6
688
January 25, 2022
When will Choose beat sync interval (1 or 4 beats) be added to MacOS version?
3
340
January 25, 2022
