1718449215 Can't load file.
Djay 2, iphone 6s+, latest firmware, Error occurs when loading explicit marked songs. Setup allows playing these songs in music app.
Hi Maik Rohland,
this error is the decimal representation of the kAudioFormatUnsupportedDataFormatError.
Can you tell us in which audio format the track is?
Cheers,Lukas E.
Hi Maik,
thank you for the follow up.
Can you send us the file via support@algoriddim.com?
Stop purchasing garbage from iTunes. First mistake.
I realized, it has nothing to do with “explicit” marking.
The file is m4a, 271kBit/s, purchased with iTunes. Other files from same album are playable in DJAY2.
Maik
I deleted the download, reloaded the file; same situation.
