1st Time DJay Mackbook Pro set up. Help Please.
DJing a gig with new Macbook pro with touch bar. Looking for minimal set up help, just using my macbook with no additional controllers. I currently have:
Macbook pro
DJay pro
Traktor Audio 2
HooToo USB hub
  1. What more do I need?
  2. How do I set this up so that I can cue the volume through my head phones. I am trying to use tracktor but it is not working. Do i need to dl any type of driver on my mac so this soundcard does what it is supposed to?
Ideally i would like to connect my laptop to traktor via USB(using my hub) then connect my headphones to traktor. Then connecting my speakers to traktor MAIN. Am i missing something? If someone can help please let me know. My email is shogun00 at g mail dot com. MANY THANKS in advance for your help. My gig is next week so time is NOT on my side.
Hey Haaris,
please install the designated driver via:
https://www.native-instruments.com/en/support/downloads/drivers-other-files/
After doing you should be able to map the Soundcard yourself via the channel assignment handler.
Cheers,Lukas E.
