Thank you for a great app for the Ipad
I have 2 questions regarding the app.
1: Is it possible to manually edit the text on a track ?
2: If you use a track where BPM changes in the song (Transitions for instance), the analysing only use one BPM, so if a track goes from, let`s say from 105 - 125 BPM, the analysing only use the 105 BPM.
How can I fix this ?
Hey hey…you can’t edit text information inside djay, I was thinking you are talking about loop & cue points
If I download my wav files from Bandcamp I change title information in the files app.
For mp3 meta information I think you have to do it with a special software. I don’t know if there is an app for this in the App Store.
Thank you for the answer.
I found a work around regarding the text issues on some of my tracks. But it could be nice to have this in the future inside the software
