Hello everyone, i actually want to know if i can use the headphone output of my controller and use a bluetooth speaker (connected to the computer) as my master output but not the master output of the controller. i know i can you do it with a macOS version since you can modify the output in the settings, but i can’t find a way to do it with my windows 10 version. i have a numark party mix as controller. Thanks
Hi Karim,
at the moment this is not possible in the djay Pro for Windows version as we are not able to support aggregate devices with wasapi - the windows audio driver.
I will let you know about news.
to summarize, i want to pre cue using my controller and to listen the active deck (master) using the bluetooth speaker (connected directly to the computer using via bluetooth).
