- Device model (e.g. 2020 iPad Air 4th Gen): iPad Pro M4 11”
- Version of operating system (e.g. macOS 14.4.1): Latest
- Version of djay (e.g. 5.1.2): Latest
- Hardware/controllers used (e.g. Reloop Mixon 8 Pro): NA
Your question:
When I’m in single deck mode, how can I access the effects? I would expect to be able to tab between FX and loops like I can in the “pro” view.
Hi @heyflorin, welcome to the Community! Please note that 1 Deck mode is mainly meant for preparing songs for a DJ set. So adding Hot Cue, Loops and adjusting the Beat Grid. FX and Samples are not supported in 1 Deck View. You can, however, access Loops (see below)
Thanks for the reply, I actually meant Looper Packs, I’m not sure what to call them since they’re also called “loops.” Is there really no use cases you’ve heard about for using FX inside the single deck mode? I personally would love to use it for performances that don’t require two decks,
Thanks for clarifying @heyflorin. You need to switch to one of the other modes, Classic, Pro, Looper or 4 Decks if you want to use the Looper or FX. These are not available in One Deck Mode. As mentioned above, One Deck Mode is intentionally simplified for song preparation and not meant for performance.
