Add Gate 1/2 Instant FX option
Device: Imac 27.5 2016
Dj controller: ddj flx4
Version of app: last
My quest: I cant change fx length
F
Example: gate 1/4 - 1/2 I CANT
Hi @Only_Main, welcome to the Community! If you want to use beat adjustable FX, please switch from Instant FX to Manual FX in the FX dropdown menu.
but i always cant to change the beat length. I want to hold the pad on the dj controller
The closest option we currently have to Gate 1/2 Instant FX is Noise Gate 1/2. Otherwise you will need to use the Manual FX option.
why cant you make this. Its is very basic function in serato-rekordbox
Hi again @Only_Main, I’ve changed your topic from a Question to a Suggestion. Please use the blue Vote button at the top left of this page so we can gauge user demand for this feature. In the meantime, I will pass this onto our dev team for consideration. Thanks!
There will be even more features that are standard in Rekordbox but not available elsewhere, just as there are features that are standard in Djay Pro but not in Rekordbox… :roll_eyes:
