For Djay pro on mac: How do I add my own samples to the sampler?
please see this FAQ article:
http://help.algoriddim.com/customer/en/portal/articles/2364125-how-to-add-your-own-audio-samples-
Hi Alex,
could you share a screenshot of your directory where you can not find the next folder?
Thank you in advance.
ok i see where the problem is.
Please open a finder tap and click on “Go” in the top menu bar.
Now press hold the alt key and a “Library” option will pop up.
In this library you will find the “Containers” folder.
Hope this is working,
Cheers.
I have DJ pro installed on a MacBook Pro (purchased from the App Store) and after a lot of searching cannot find this folder. Love to be able to load my own samples. Does anyone have any ideas?
Hey Lukas - thanks for taking a look - here are two screen shots. Even when I search for “Algoriddim” the only thing that appears is the actual djay Pro App. I’m running OSX 10.11.5
That did the trick – thanks Lukas!
And windows???
