I am trying to figure out two things but either would be helpful:
disable the pitch correction for tempo changes (controlled by key lock i assume) for only one stem and not the others
apply a pitch-shift FX to one stem. I know how to route it to the stem but cannot find a specific effect that simply changes the pitch. i see there is a pitch cue function for Mac but apparently not for windows and android
i searched in a lot of places so please don’t delete or lecture me without reason
Also, a workaround for disabling Key Lock on a specific STEM would be to create and Instant Double of the same song onto a second deck, then separate the STEMs accordingly for each deck and disable the Key Lock on the want you want to change the pitch.
I also explain in this topic how to custom MIDI map a STEMs-Split function which would probably be helpful in your use case:
Hi again @theoryhater0, I have changed this topic from a Question to a Suggestion and have adjusted the title slightly for clarity. I will pass this onto our dev team for consideration. In the meantime, please use the blue Vote button so we can gauge user demand for this idea. Thanks!
