Add support for Denon Prime Go
Hi Maurizio
i don’t know what is wrong with your FX section because with default 5.2 Algoriddim mapping the fx section now works as expected on the Prime Go without any modification… and my mapping is just a modification of this default mapping with just vumeter lights added…
Regards
I am on iPad Air 5th Gen,
My FX work fine but I had to map them to various buttons,
The buttons I am referring to are the Assign 1 & 2 buttons…
This is for the Manual FX.
The Instant FX work fine as per the Djay 5.2 map
On your original map (pre 5.2) pressing those buttons as well as the On (FX Select button) would give a midi command, with the 5.2 version they no longer do…
It’s not a problem for me as like I said I have mapped other buttons to do that…
Here is what I have done,
Buttons A & B (Under the sweep FX dial) now Enable FX1 and FX2 on each deck.
With the 5.2 built in map, Button A enables Neural Mix Solo (2 channel Instrumental) whilst Button B enables (Neural Mix Solo 2 Ch. Acappella)
FX 3 enable for Deck 1 is enabled by pressing down on the FX select dial (It has a built in button as well as being a dial)
FX 3 enable for Deck 2 is enabled by pressing down on the FX Time/Parameter dial
Another one that I have mapped is
Back button toggles Neural Mix- Eq for Deck 1 and the FWD button toggles Neural Mix - EQ for Deck 2.
The Eject button (Top right corner) I have mapped to Start Recording
On/Off)
These are just a few of the Midi actions I have mapped…
Thanks Maurizio will try this
This is always my biggest want as a hardcore Denon user. Also really don’t like the fact that there is no sc5000m and 6000m support but other motorized devices have no problem .
Using control waves on the denons is at least a workaround but denons are the absolute king for bet value for price. Djay I’d also the same in my book and would really make a statement by fixing the demo screen issues and the motorized player issues
Thanks for the feedback @Deedot
yes more support for Denon Prime Go :100:
VirtualDJ works om Prime Go screen
Needs support for the screen, waste of time with no screen support.
I thought of that as well when I first bought my Go but to say the truth, the size of the screen is a bit small compared to my iPad so I am used to that screen,
My set up is very compact now.
Can anyone help me? I’m trying to get VU meters to work on my Traktor Kontrol S5.
The VU meters do work when i use SendMIDI (from github) So when i do “sendmidi dev “Traktor Kontrol S5” ch 11 cc 28 127” in macos terminal, the VU meter shows all leds on. But when i use this code ini djay midi map:
<plist version="1.0">
<dict>
<key>outputs</key>
<array>
	<dict>
		<key>controlType</key>
		<string>control</string>
		<key>keyPath</key>
		<string>turntable1.monoMeter</string>
		<key>midiChannel</key>
		<integer>11</integer>
		<key>midiData</key>
		<integer>13</integer>
		<key>midiMaxValue</key>
		<real>127</real>
		<key>midiMessageType</key>
		<integer>3</integer>
		<key>midiMinValue</key>
		<real>0</real>
	</dict>
	<dict>
		<key>keyPath</key>
		<string>turntable2.monoMeter</string>
		<key>midiData</key>
		<integer>28</integer>
		<real>66</real>
		<real>13</real>
	</dict>
</array>
I does not work. Why?
thanks.
One reason to take a closer look at the Prime Go+ is the option to use DMX for lighting control. But does that also work when using the controller with Djay Pro?
You can’t access the prime go screen in computer mode so i wouldn’t think so.
Initially I wished that there was access to the Prime Go using Djay Pro but I’m now used to the size of my iPad so dropping down screen size would probably be a downgrade for me,
What I do wish for is if Denon would show the battery status level in computer mode.
I did ask in a seperate thread but I will ask here as well,
Does anyone have a Prime Go + that is using it with Djay Pro on IOS?
The one little gripe that I have with the original Prime Go is on the Filter and EQ pots, it takes a bit of movement from centre either left or right direction for it to respond in Djay..
Probably 1 mm of movement.
Just wondering if this was sorted in the Prime Go+
I almost thought so… too bad. That would make the controller much more interesting for me (and certainly for many others), as would the Mixstream Go, for example.
I think I could live with the smaller screen if Algoriddim Djay were integrated. Alternatively, I’ve also considered trying out Engine DJ, but using stems requires prior editing on the computer. And that would be a huge step backwards.
Engine feels prehistoric after using djay pro. Way too much effort with beatgrids and stems and no midi mapping either.
VirtualDJ shows up on Prime Go screen. All buttons and knobs work.
Very interesting.
I’m not a VDJ user though and it requires the pro license to use so I probably won’t be trying it.
