I recorded a 5 second silent break to use between songs on a playlist and copied it multiple times to use between songs on an iTunes playlist. When using the playlist on djay 4 and using autoplay, the “break” track is “checked-off” after the first time and won’t repeat. Is there a way to repeat the same track on the same playlist in autoplay.
