Hi
I’m testing DJ-Pro on my Mac before buying it.
It looks like a great program only i have one problem. When i use my iTunes playlist and i change my output to airplay, my airplay speaker (Bose) go’s to max sound :-/
Is there a way that, when i change my output, the sound level stay the same instead of going to maximum? Now i have to quickly have to lower down the level not to damage my speakers.
If this works i properly will buy this program because this is the only problem i have for the moment.
regards & thanks
