I am working w NUMARK Mixtrack Pro II. Not all functions work w DJay Pro it seems. For example - to re-set the “que” point to the beginning of a song supposed to be able to hold down “Shift” and cue…nothing happens!
Also if I use DJay Pro to search iTunes (within DJay Pro), the program either stops the current track playing or has a freeze? If I search in a separate window my open iTunes Library and drag the song to the DJay pro window - it works??
I guess that probably depends on how the relationship with Numark stands. I wonder how well the idj Pro sold? I still use one and love it, but would buy a four-channel machine straight away.
What about Djay Pro for iPad?
I currently use djay2 and an idj Pro, but I’m looking for four channels to play with, so I was hoping that you might be thinking of sorting us iPad-users out. Presumably, if you did, it would be compatible with the Reloop Beatpad?
I don’t use CDs at all, but I hear you…laptop (with Pro) and Beatpad then.
Oh, of course…now I feel stupid lol! I had the Numark Mixdeck Quad in my head.
Beatpad has no deticated c/d deck buttons.
And in another thread, they said its not going to happen.
I think we have to upgrade to pro, for that.
CD’s?? i mean 4 decks… Deck A/B/C/D. What are CD’s
Thank you guys for this feedback!
I hope you can get along with our natively supported controllers, for now.
Have a look at: http://www.algoriddim.com/hardware
@Hitchcock: For iOS, we offer a similar software to djay Pro: djay 2 → Check it out at the App Store!
@Paul: Please contact our support team so we can troubleshoot this issue -> support@algoriddim.com
