Allow 2-3 Main Output Effects at a time
YOUR SUGGESTION:
  1. Sería muy bueno para mejorar el sonido en Djay que la aplicación pueda permitir aplicar 2 o 3 efectos al mismo tiempo en efectos salida principal ( Auv3 plugin IOS )
  2. Esto lo hace el reproductor Foobar2000 en :wink: IPhone y IPad y es extraordinario.
  3. Otra sugerencia para facilitar el uso en Djay sería que al cerrar la app ,esta guarde la última configuración de equalizacion y efectos de salida principal asi como las dos últimas canciones que están cargadas en los platos.
  4. Tenemos que conseguir que Djay sea también nuestro reproductor principal de audio en iPhone y IPad para escuchar música no solo para pinchar música
  5. Muchas Gracias
ENGLISH TRANSLATION:
  1. It would be a great improvement for sound quality in Djay if the app allowed users to apply 2 or 3 effects simultaneously via the main output effects (using iOS AUv3 plugins).
  2. The Foobar2000 player does exactly this on iPhone and iPad, and the results are extraordinary.
  3. Another suggestion to make Djay even more user-friendly would be for the app to automatically save the last EQ and main output effects settings—as well as the last two tracks loaded onto the decks—whenever the application is closed.
  4. We need to ensure that Djay becomes our primary audio player on iPhone and iPad—used for casual music listening—rather than just a tool for DJing.
Thank you very much.
Hi @Alien, welcome to the Community! Please translate your posts to English. Thanks!
I have translated you post for you @Alien. In the future, please translate to English before you post. Thanks for the suggestion! I’ll share this with our devs for consideration. In the meantime, please use the blue Vote button at the top left of this page so we can gauge user demand for this feature. Thanks!
