On DJAY Mac:
Is there a MIDI mapping that allows you to send a track to the automix list? I noticed an “add to queue” but no “add to automix”. Bonus! If you could have the automix source be the queue, this wouldn’t be a problem (I believe this is the case for iPad version)
Hi @javosanc, there is no dedicated MIDI command to add song to Automix.
If you start by loading songs from the Queue playlist into the Decks first then select Automix, you will be able to Automix using the Queue playlist.
Thank you for the answer! Yes, I know you can use the Queue as a source for the automix, but this only works on iOS. The MacOS version doesn’t have the option to use the queue as automix source
Hi @javosanc, I didn’t realize Automix via the Queue playlist was not possible on macOS - you are indeed correct. I have changed this topic from a Question to a Suggestion and have forwarded this to the dev team for consideration. In the meantime, please use the blue Vote button at the top left of this page. Thanks!
