AlphaTheta XDJ-AZ Official Support
I just got my new XDJ AZ, but I’m wondering if it is not possible to search text via the AZ Screen in Djay Pro (on Mac OS). Currently I can scroll through my playlists, but not search for any song title. Maybe my setup is wrong? I think on the old CDJ 2000 NXS, it was possible via HID Mode and DJay Pro.
Hi @Christian_N, I don’t have access to and AZ to check for myself, but I’ve passed this onto our hardware team to check…
Hi again @Christian_N, I heard back from our hardware team. Unfortunately, search was never possible on any CDJ, nor is it possible on the XDJ-AZ. This also doesn’t work with Rekordbox. The search function on the CDJ or XDJ does not work with an external software source.
What is possible: type your search into the search field within the djay UI (this updates the browse view on CDJ/XDJ to the current search results), then browse the search results using the browse encoder.
Thank you for the quick response @Slak_Jaw. Then I was wrong in my mind with the CDJs. I though place my Mac somewhere away from the DJ booth, while I’m using DJAY Pro and XDJ AZ.
You’re welcome @Christian_N
Hey folks,
Just after a bit of advice on the XDJ-AZ and djay Pro integration.
I’m mainly a vinyl DJ and haven’t actually DJ’d out much recently, but I do use djay Pro a bit at home with Reloop flux. I’m playing at a mate’s 50th in the summer and there won’t really be an option to set up decks. The venue has an XDJ-AZ though, and I know the guy who owns the bar, so I should be able to have a quick test on it beforehand.
What I’m trying to work out is whether djay Pro is reliable enough with the AZ for a fairly straightforward party set.
I’ve seen a few comments above about sound quality issues, so that’s my main concern. I don’t need loads of advanced functionality as I’m used to vinyl anyway but I do need the basics to be solid so I can play and mix.
Is anyone here using djay Pro with the XDJ-AZ regularly, and if so, has it been stable?
Also, has anyone tried this with an iPad or iPhone rather than a laptop? My ideal setup would be to turn up with an iPad or phone, plug into the AZ and mix from there, but I’m not sure if that’s too risky? If it all goes pear shaped it’s my mates at the end of the day so not like a paid gig.
Would be really useful to hear from anyone who’s actually used this setup, especially whether it’s stable on laptop vs mobile/iPad.
Thanks.
Andy
Hi @AndyR, welcome to the Community! I don’t have access to this hardware myself so I can’t share any personal hands on experience.
Please note the following limitations with this device:
  • The screen is only supported on macOS and Windows, not on iOS.
  • Neural Mix EQs are not supported - the XDJ-AZ EQs are mixed externally on the hardware and they don’t send MIDI. Therefore they can’t be MIDI mapped in djay.
  • Track preview on headphones from within the library view is not supported. The XDJ-AZ does not have a dedicated physical channel to route track preview to the headphones. This is a hardware limitation.
Will screens ever be supported on iOS or is there an inherent limitation that prevents it?
Hi @amattas, I believe this would require a firmware update from AlphaTheta so it might be possible at some point. I can’t say for sure though.
Thanks for the info, @Slak_Jaw I think I’ll see if I can test it before the gig.
Andy
You’re welcome @AndyR. Sounds good!
