djay isn’t reading these files… Only those in iTunes
djay for iPad directly integrates the iTunes music library on your iPad. Though there are ways to load songs from other apps in djay:
- via “Open in…”: http://help.algoriddim.com/customer/p…
- via Audio Copy&Paste
This only works if the other app (in your case the Amazon app) supports the respective feature as well.
Otherwise, I recommend syncing the songs to your iPad via iTunes.
