Device model (e.g. 2020 iPad Air 4th Gen):
Version of operating system (e.g. macOS 14.4.1):
Version of djay (e.g. 5.1.2):
Hardware/controllers used (e.g. Reloop Mixon 8 Pro):
Please consider sharing a short video or screenshots to help clarify your question
YOUR QUESTION:
Bonjour ! J’utilise djay pro sur un MacBook Pro de 2019 et un iPhone 17 pro max et je voulais savoir si il existe un moyen pour que une analyse de morceau ou de playlist pour les bpm et clés harmonique sur mon MacBook puisse être synchronisé avec mon iPhone afin de pas avoir à tout reanalyser une seconde fois ! Merci
Hello! I use DJay Pro on a 2019 MacBook Pro and an iPhone 17 Pro Max, and I wanted to know if there is a way to synchronize a song or playlist analysis for BPMs and harmonic keys on my MacBook with my iPhone so that I don’t have to re-analyze everything a second time! thanks
Hi @Ineddy86550, thanks for translating your post into English. Not through iCloud, unfortunately. iCloud syncing keeps your cue points and loop regions in step between the Mac and iPhone, but BPM analysis isn’t synced, so each device analyzes tracks on its own as they’re loaded.
If you want to skip re-analyzing on the iPhone, try OneLibrary. It stores BPM, key, waveforms, beatgrids, cue points and playlists right on a USB drive:
On the Mac, format a USB drive as exFAT or FAT32.
Right-click a playlist in djay and choose Add to USB Library.
Eject the drive safely, then plug it into the iPhone with a USB-C adapter.
In djay on the iPhone, tap USB Library in the sidebar and select the drive.
One thing to know: OneLibrary is read-only on iOS. You’ll play those tracks from the drive, and any playlist edits have to be made on the Mac. I hope that helps!
Hello! Sorry for not replying to you! After your last response I have understood correctly, so for the moment I continue to work as I was doing! You can close the discussion! Thank you for your help! I love Djay Pro, it’s a fantastic software and I don’t regret leaving Serato.
