you can put compatibility with djay 2 ddj pioneer sb also on Android?i think it’s a good idea
Hi Lawrence,
thank you very much for contacting us!
Unfortunately the Pioneer DDJ SB is a Mac only controller, so it is impossible to use the controller with a mobile device.
I hope you understand the situation.
Thanks for your request.
Best regards,
Alex
