Hello,
not amused about the fixed lines in “nowplaying.txt”, I want to use applescript creating my own “nowplaying.txt” that fulfill my needs. Additionally I want to display Artist and Title in Adium.
I drag DJay on AppleScript-Editor to receive a list of funktions and possible parameter, but I get a error-message:
“Das Funktionsverzeichnis des Programms oder der Erweiterung konnte nicht gelesen werden, da sie nicht scriptfähig sind.”
NowPlaying.txt is intended for NiceCast. If you need a similar text file but in a different format, you can simply write a script (e.g. Ruby script) that reads NowPlaying.txt and writes a new text file which suits your specific needs.
with the friendly help of the programmer of B.u.t.t., I created my workaround.
He wrote a scriptline to extract the Metadata of NowPlaying.txt into a new file that B.u.t.t. could read correctly. I converted this to a command and wrapped it with applescript into an app.
