I am using the latest version of djay on my macbook.
I teach dance classes and need software that will:
- Take my playlist in apple music
- Sync BPM of tracks in play list (generally about 10 tracks)
- Crossfade so that there is no pause or silence between tracks
This allows a full hour of movement at the same tempo.
I am wondering if this is possible with djay pro. I have watched a few videos and poked around a bit, and can’t find basic tutorials on to help me get started.
Automix can do it:
Basic Instructions:
- Open Automix Window (bottom-right)
- Select playlist and load first track
- Start Automix
Notes: You will need to futz around in Settings to get it working right: For the full set of options, look in Settings → General and Settings → Automix.
That was probably such a no-brainer for you, but you are an absolute hero for this-- thank you!
Hi @mizmaclean, welcome to the Community!
Thanks for the help @Michael_Wisniewski! Perfectly explained as usual!
