Your question:
Hello , I have questions for anyone who may be able to help. I have a Numark Platinum FX Controller. I want to know is there a way to assign my FX in DJ Pro algorithm , like Reverb , Flanger Ext… to the Pads on the Numark Mixtrack Controller ??
Hi @DJEXTRO, this can be done, but will likely require a bit of MIDI mapping and setup on your end. I don’t have access to this hardware to confirm if Instant FX pads are already MIDI mapped to one of the Performance Pad Modes or not, so let’s assume they are not.
- Let’s start by switching djay to Pro Mode so we can see the FX section UI.
- Then select the FX UI mode at the bottom and choose Instant at the top.
- From here, select the edit Pencil icon and then the “…” next to each pad.
- From here you can assign the FX that you like to the top 4 Performance Pads.
The next step is creating a custom MIDI mapping for the Instant FX Pads. Please refer to the linked FAQ below on how to MIDI map in djay for iOS first:
You will specifically want to MIDI map the following to each of the top 4 Performance pads for both Deck 1 and Deck 2 of your controller:
- Press the Performance Pad 1 for Deck 1 on your controller.
- Set the Target>Deck 1
- Set the Action>Instant FX 1
- Then repeat this for Performance Pad 2: Target>Deck 1, Action>Instant FX 2
- Performance Pad 3: Target>Deck 1, Action>Instant FX 3
- Performance Pad 4: Target>Deck 1, Action>Instant FX 4
- Then do the same for Deck 2, but be sure to change the Target>Deck 2
- Press the Performance Pad 1 for Deck 2 on your controller.
- Set the Target>Deck 2
- Then repeat this for Performance Pad 2: Target>Deck 2, Action>Instant FX 2
- Performance Pad 3: Target>Deck 2, Action>Instant FX 3
- Performance Pad 4: Target>Deck 2, Action>Instant FX 4
I hope that helps!
