Has anyone tried the new Audacity yet?
I am liking the new interface and dark theme, although you can revert to the light interface if you prefer. The editing workflow has improved:
- New split tool.
- Clips been able to be dropped anywhere.
- Select multiple clips, then move, trim or stretch them as one.
- Select your clips and choose “Group clips” from the right-click menu. The group moves, trims, and stretches as one until you ungroup it.
- Switch on the envelope tool and click to add points along a clip. Drag them to set the clip’s gain, and it stays with the clip when you move or copy it.
- Trim and stretch handles.
- Per track metering.
- Markers and regions.
- Loop region controls.
This is just a short list taken from their website.
Audacity is great if you need to make edits to a track or a set you have recorded.
I would love to hear your thoughts ![]()
