Audio Routing Display Inconsistency (NI Audio 10)
There is a UI display bug when configuring audio output channels.
Environment:
  • Software: djay Pro v5.6.1 for Windows
  • OS: Windows 11
  • Hardware: Native Instruments Audio 10 (ASIO)
I believe there was previously a bug where the display would change when setting the audio device.
Recently, I changed my setup to output from the NI Audio 10 so that I can use multiple controllers in the same environment. Since then, the display shows unintended channels every time.
Example: I have the monitor output set to ‘1-2ch’, but ‘3-4ch’ is displayed. However, internally it seems to be set correctly, and the audio is routed properly. It appears to be strictly a display issue.
Additional note: It would be very helpful if there were an option to save the audio settings.
Thanks for the details and video @megamema. Very helpful! I don’t have an Audio10 to test myself so I’ve passed this onto our hardware team to see if they can reproduce it. Thanks!
Our engineering team was able to reproduce this and they’re investigating further.
Hi @megamema, our engineering team has identified the issue and is working on a fix which should be included in an upcoming update (likely 5.6.3). Thanks!
Hello everyone, 5.6.3 was released today and should address this issue.
