I’ve just downloaded djay pro for the iPhone and I was wondering where the option had gone to split the crossfader video/audio to be able to crossfade them separately. It was there in VJay?
Ah! Thank you. There seems to be a bug also hat if you are in portrait mode it won’t always switch, landscape mode is fine though then when you flip it seems to be ok!
It is under the transition mode selection …located at the bottom
No pro:) hmm as for the bug you mentioned , I have not encounter it yet and it is so far so good but I will keep a lookout now .thanks!
