Automix does not pickup all the playlist stored on iTunes. It shows only the first playlist. If i wanted to choose another, i had to go to and refresh playlist everytime i wanted to change the auto mix playlist. This does not happen though on the iPad version only on the MAC.
Hi i am using Itunes version 12.5.3.17 running on a Mac book pro 15" Retina 16 GB Ram.
Hi Derrick Ramkalawan,
can you tell us which iTunes version, device and operating system you are using?
thank you for the follow up.
djay Pro for the Mac picks up the playlist, genre, interpret, album … you have selected in the library and suggests a playlist of these category.
If you select another iTunes playlist in the library you will be able to start the automix for that particular playlist.
I hope this is helping.
