Automatic chronological sorting for Hot Cues and Saved Loops
SUGGESTION:
  1. Hi, it would be great if you could add a function in the settings menu to enable or disable automatic chronological sorting for Hot Cues and Saved Loops. Coming from Serato, this is a very practical feature that I really miss in djay pro.
I recently found out you can manually change the order of the cue points when you press the pencil icon.
(I know it’s not automatic sorting, but at least you can change the order manually)
Hi @dj.ferestec, welcome to the Community! Thanks for the suggestion! I’ll share this with our devs for consideration. In the meantime, please use the blue Vote button at the top left of this page so we can gauge user demand for this feature. Thanks!
