I’m still getting used to the automix feature but I’m noticing the 15sec cross fade isnt enough. Some of the songs I’m using have a long fade out and 15sec isnt covering it. Theres silence between songs. I’ve tried to increase it but 15sec seems to be the max for automix cross fades.
Has anyone had this issue?
Do you have djay for Mac, iPad or iPhone?
The Mac version currently only supports 15 seconds max. But on the iPad and iPhone version, you should be able to select up to 60.
All of them but I’m mainly working on my Mac.
Thank you. Do you think this will be changing in the Mac version anytime soon?
