- Device model * MacBook Air m2
- Version of operating system *(e.g. macOS 15.
- Version of djay *(e.g. 5.3.1
Summary of the issue:
automix when we switched to the next song that slow feature bring the song down slowly had to fix the issue I have to mentally make it faster the system can automatic match the speed in settings
How to reproduce the issue:
Hi @Cooljackdj, I’m having trouble understanding your text explanation of the issue. Could you please try explaining it with a short video instead? Thanks.
My best guess is that you do not want the tempo to change during the Automix. If that is the case, please navigate to the djay Settings>Tempo Adjust and set it to Sync instead of Automatic.
If you are using the Crossfader FX instead of Automix, then you’ll want to disable Tempo Blend to keep the BPM the same during the transition.
