when I open the automix preferences, I can only automix radio. why can’t I automix the current playlist selected?
Hey Luisa Severo,
can’t you select an Automix playlist in the playlist tab?
Can you select the playlist you want to use in the library and go to the Automix playlist tab afterwards?
Cheers,Lukas E.
no, the only feature available is adding all of them to queue.
where should the automix button be?
thanks!
