Hi again @JeroenDutchy1, I’ve merged your topic with this one as they appear to be the same issue. I have reported everything from both topics to our engineering team and they are investigating further. In the meantime, as a workaround, can you please try adding your trouble Spotify songs to a new playlist in the My Collection Source to see if the issue persists?
I made the workaround and this give no problem in automix, the problem songs are all refreshing in de player, so this works fine.
I made a new playlist in Spotify with the 2 songs ‘on the floor’ , as requested (here the radio version has no problem in automix). The playlist is called : On the floor DJAY.
Hope you find the problem when directly playing de spotify playlist in Djay.
That’s great to hear! Thanks for the follow up @JeroenDutchy1
Hallo,
Ich habe das gleiche Problem. Allerdings auf Windows. Er läd immer einen Track hinein nach ein paar Liedern. Zusätzlich kann ich keine neuen Playlists zum abspielen auswählen. Um eine andere Playlist in den Automix zu legen muss das Programm neu gestartet werden.
Wann gibt es dafür ein Update? Das ist aktuell so nur sehr schwierig nutzbar. Ein Neustart ist schwierig wenn man gerade etwas abspielt für die Tanzfläche.
Hi @Philipp_Hanenkamp, welcome to the Community! Please translate your post into English. Thanks.
I deleted and recreated the Playlist and it worked
That’s good to hear. Thanks for sharing @Kissfreak
FYI,
It does the same thing on windows.
That’s just broken. I had people send me playlists directly for their wedding and such. Took me hours of frustration and embarrassment to figure out what was happening. Looks like I’ll be recreating a few playlists…
Hi @Alan_Thompson, welcome to the Community! Sorry to hear you’re experiencing this issue on Windows as well. Thanks for sharing. In the meantime, recreating your playlists in the My Collection source appears to be an effective workaround.
