Automix Start and End points on PC
  • Device model (e.g. 2020 iPad Air 4th Gen): HP 016 Omen
  • Version of operating system (e.g. macOS 14.4.1): Windows 11
  • Version of djay (e.g. 5.1.2): 5.6.9
  • Hardware/controllers used (e.g. Reloop Mixon 8 Pro): DJ2Go2
YOUR QUESTION:
  1. How can I select the start and end points of the next song on PC? Is the next song not supposed to be that far over?
Hi @djdoubled, welcome to the Community! You need to set the Start and End points of your songs before you begin an Automix session. Yes, the next song is intentionally shown in that position, but there is an existing community suggestion to change this if you would like to upvote it.
