What happened to the constant BPM when using Sync in Automix? I usually my BPM and there has never been a change.
I know there’s threads here talking about it, however I’ve selected Sync and it still changes BPM.
Same thing happened to a friend of mine a few days before it started happening to me.
Have been using DJ Pro for years and I’ve never had this issue in Automix. I use Automix mainly for organising a mix and casual listening. It’s incredibly frustrating and I end up scrapping DJ Pro Automix.
Hi @adrianamos, you just need to adjust your Automix Settings>Tempo Adjust from Automatic to Sync. This will maintain the BPM during transitions instead of blending it from one song to the other. We added Automic in 5.3. With this setting djay will essential keep the BPM the same during transitions unless the songs are more than 5% apart. In that case it will automatically switch to Tempo Blend.
This is what it looks like on iOS, but should be similar on macOS.
I posted on Facebook last night that I noticed Automatic did change BPM if there was a larger difference in BPM.
As mentioned though I always set Tempo Adjust to Sync.
I’ve checked the release date and it started happening to me on the 11th April and to my friend a few days before, so it would’ve been with the 5.3 release on the 8th April.
Hi again @adrianamos, did the Forced Restart suggestion above work?
Our engineering team has not been able to reproduce this either. We need to figure out under which circumstances this happens, e.g. does it only happen with specific songs or specific BPMs, or does it always happen for you? Thanks!
It seems to have resolved itself.
It seemed to happen with BPM ranges greater than 5%. It was as though Tempo Blend was turned on, even though as I mentioned I always use Sync only
For auto mixes.
