- Device model (e.g. 2020 iPad Air 4th Gen): HP Elite Book 6 G1i
- Version of operating system (e.g. macOS 14.4.1):Windows 11 Enterprise
- Version of djay (e.g. 5.1.2):5.6.8
- Hardware firmware version (e.g. 1.0.1):
- Please consider sharing a short video or screenshots to help clarify your issue
- See screenshot, “Up Next” is half cut off no matter what i do i cannot change it
- just login and use automix
C) EXPECTED RESULTS:
- Up next should be fully visible
D) ACTUAL RESULTS:
Hi @Andy_Hamilton, welcome to the Community! Thanks for the setup details and screenshot. Can you please also capture short fullscreen video recording of this? Thanks!
I’ve given you video upload permissions. Please try again.
Also, the Google Drive link doesn’t have sharing permissions enabled so I can’t download your video there.
Either way @Andy_Hamilton, I think I see what you mean and I believe this was a deliberate UI design decision as it looks similar on iOS. I you’d like to see you Up Next tracks in full, I recommend enabling the Automix Side Panel
or running Automix in Two Decks Mode
Thanks @Andy_Hamilton. As I said above, I believe this was an intentional UI decision and is not actually a bug. I do see your point though, so I’ve changed this topic from a bug report to a suggestion and will forward it to our dev team for consideration. In the meantime, please use the blue Vote button at the top left of this page so we can gauge user demand for this design change. Thanks!
