Backspin duration problem
  • Device model (windows pc):
  • Version of operating system (windows 10):
  • Version of djay (5.1.2):
  • Hardware/controllers used (Hercules inpulse 300 mk2):
YOUR QUESTION:
  1. Whenever I try to backspin on djay pro the backspin duration is always cut short even though the wheel on my controller is still spinning the software only slightly lunges the track back. So basicly the wheel still sping while backspin only sounds like a scratch not backspin at all. How do i fix this?
Hi @Pavel_Bartos, can you please share a short video of this to clarify what’s happening?
It’s hard to tell from your video @Pavel_Bartos,
Can you please confirm if your jogwheels are set to Vinyl Mode? You can toggle this on the hardware with SHIFT+SLIP.
