Hi, I can see where the beat fraction is in the manual section of the FX dialogue. But it’s currently set to ‘1’ and greyed out and didn’t slow me to change the value.
How can get it to change?
Beat fraction is only available for certain FX like the Echo. To change the fraction press the left or right arrows on the touch screen (see below). If you have a MIDI controller you can also map these arrows to 2 free buttons or an encoder on your controller. Also keep in mind that the max and min values are different for each effect. Some don’t go above 1 and some do.
Could also be that this feature is only available with the PRO subscription. Do you have that, @Cheekybeelzebub?
