Your description on App Store says ‘we can grab a beat from the music you own or even sync with your spotify account, then tap a button and Djay pro will analyse the song you’re playing to find other songs that’ll fit the beat’
How do you do this? Cheers
the music matching function is working in your iTunes library and in Spotify and you can access the function via the “2 vinyl icon”(see attached screenshot).
Please note that the data input is only your local library when using this function in iTunes and the whole Spotify database for the used in Spotify.
Cheers.
