Beat Sync slips slightly
  • Device model: MacBook Pro M2
  • Version of operating system: Sequoia 15.5
  • Version of djay: 5.4.2
QUESTION:
I am using DJPro with no midi, hardware. just messing around in the UI. (The keyboard shortcuts are super nice :slight_smile:
I have now noticed on more than a dozen plus tracks, the sync slips mixing tracks.
I have purchased tunes from beatport or Bandcamp. Mostly electronic music. I find it is particularly noticeable when there is no bass line.
From what i can tell, navigating the UI, I have the tracks set as Direct in the BPM settings. Sync is on. I have tried both 4 and 1 beat. no difference.
Is this a thing? Like it is a tiny fraction off but with a 4 x4 it is noticeable and annoying. Putting this out there as i don’t know what i don’t know and am happy to be told otherwise. Is there a setting I am missing? Or this is how it works?
Hi @Narbeh_Yousefian, welcome to the Community! Since this sounds repeatable, can you please capture and share a short video of the issue to help clarify what’s happening? Thanks!
Hi @Slack_Jaw thanks for the speedy reply. Sure thing. See image.
Not sure that image helps but figured if it is in sync the bars would be tidier.
FWIW may have been a memory thing? Not sure … I have been playing with it all day lol, so kudos on an awesome app. But I restarted it and issue went away.
You’re welcome @Narbeh_Yousefian. As requested, can you please share a screen recording instead of a screenshot?
