Beatgrid editing UI on Android.
  • Device model Android Poco F7 pro:
  • Version of operating system Android:
  • Version of djay 5.5:
  • Hardware/controllers used n/a:
Your question:
Got the new 5.5 update on Android, read the changelog but I don’t see this improved UI gor beatgrid editing?
In fact, cant seem to do much with the beatgrid on Android.
Thanks.
Hi @Stephen_Carroll,
  1. Make sure you are in Classic Mode and not Starter Mode
  2. Put your Android device in landscape orientation
  3. Enable the Performance Tools
  4. Then select Hot Cues Tools
  5. Then select the drop down menu for Slice, Skip, Edit Grid
  6. Finally, select the Edit Grid option.
Thank you. Never would have found that!
You’re welcome @Stephen_Carroll
