Hey
I have a problem with my beatpad2
One of the eight drumpads pads sometimes works but sometimes not, can someone help me?
Verstuurd vanaf mijn iPad
Hey
Sounds like a hardware problem, so you should contact the seller, or reloop. This is the software forum for algoriddim.
You could try to hook it to a computer with suported software and try the pad there. Same problems? Definetly a hardware isseu.
yes it would be great if you could try DJ Ivan’s suggestion and try to the Beatpad with another iOS device or Mac if you got the possibility.
Thank you in advance.
