Beatpad2 'stuck' in update mode
I was attempting to upgrade my firmware to the latest version compatible with IOS10.
I followed the directions but my mac says it "cannot find device’ and the beatpad2 won’t turn on but you can hear a clicking sound. I read that this could be stuck in update mode??
Is there anyway to reset so I can install the new firmware?
Thanks for the advice
Mark
Hi Mark,
glad to hear that things are back to normal.
Mark would you put your findings up on the reloop website as there are other folks with the same problem
Ok, so I managed to fix this myself by using the Windows update instead of the IOS update. Happy Days!
