Behringer BCD 3000 mapping
Wondering if anyone out there has either a map I can use or can help me out in mapping my own. Having trouble with FX controls and looping/cue controls for each turntable. Also as it is right now my FX controls only work for turntable 1 but probably my fault with how I have it mapped right now.
Hi Keith,
In the configuration window, you can select “Turntable 1” or “Turntable 2”.
Hope this helps.
