Best full-size controller for day pro
I’m on the hunt again for a new controller for this app. I have tried to like the mixon 8. But the build quality is just terrible and there’s so many little things that I’ve just had to ignore. I had to send two back and still having issues with the one I have.
What are the controllers would you recommend for use with this app with an iPad Pro
Rane One works very well. The problem with controllers with screens (Rane Performer) is that they’re not class compliant so you won’t be able to take advantage of the screens on the platters. Need a laptop for that from what I understand. I’ve used the Rane one for years and have no complaints.
I have a Rane one also. This controller is good enough for me but might be horrible for you.
I recommend the Grv6. People seem to be happy with it since it’s now supported and it’s cheaper than the Rane one.
Thanks for your input guys. I don’t need spinning platters. I’ll look into the other controller you mentioned
How many channels do you need? I have pioneer rev 5 and it’s great. Really well mapped for djay pro.
I need 4 channels really , do a lot of evens where I need to plug in extra inputs
I know it has no screens working but flx 10 then maybe? No screens would do my head in though.
That could be it. No screens on my Mixon 8 anyways
