Iv noticed when playing my gain levels drop and then when I touch the gain knob the volume levels rise. I have the latest beatpad 2 firmware, latest iPad Pro update and I’m on the last iOS 9 update. Wondering whether this is a reloop issue or algoriddam.
Hi Dysfunk DJ,
can you give us some further information about your Audio settings, are you playing with (Auto Gain, Reset EQ etc.).
Thank you in advance.
Any ideas?
Auto gain is on and reset eq is off. Thanks for quick response. Oh I just updated to iOS 10 so will need to test.
