Mine is working too! Thank you!!!
Same issue here.It’s been fine up until now.
Update: It logs in fine on my Macbook (OS 10.13) but not on my iMac (10.11).
I really need my iMac tonight.
Thanks Rob. Unfortunately my iMac is at it highest OS available. The app has been logged in fine up until today.
Call logged with them about 9 hours ago. No response.
Mine has just started working right now.Tested the login and the correct login window was available.
Ive got the same problem on my iPad, its an iPad 2 running in a Numark IDJ pro.
Its worked seemlessly for years and now all of a sudden just a white login screen for the Spotify connection. Any ideas
OK thanks
Strong work, all up and running again
same issue here blank screen. need help. this is how i make my money
back up and running…thank you
HI guys,
i’ve the same problem, unfortunately I’m working whit us and so I need that it will work fine.
Any solution?
anybody know other apps that can be used with Numark and are interfaced with Spotify?
