Bluetooth audio compensation
Hi all!
With the spread of mobile-setups and portable Bluetooth speakers I was wandering if is the case of developing an audio compensation system for Bluetooth audio.
I found that is very frustrating playing with ~0.6sec of latency from click to audio out. Is even not possible to play properly.
Since is not possible to affect the receiver audio devices, I was thinking if there is a way to affect the software side with some kind of compensation options.
I’m aware that there is a lot of variables, but I hope to plant a seed for something that I think is super useful for on the road djs and improvised setups
Impossible!
Just buy the alpha theta sonic link headphones + transmitter
That won’t work via Bluetooth, especially if you want to work “live.” The technology would have to know when you press a button or trigger an effect in order to calculate it accordingly—which is difficult :wink:
There is something called SKAA with a latency of up to 9 ms, but it’s not widely used yet.
I don’t mean only for headphones but for speakers
This is exactly what I mean, it’s difficult and nobody did it, could be a one of a kind feature.
I also already checked the SKAA protocol. It’s just a fancy bluetooth and it’s very limited, also need an external device for rx-tx and is 5x more expensive than an uhf system with almost 0 latency, the idea behind skaa is good but it’s held back by its own technology… I don’t like it.
The idea is to compensate through the instructions on the UX what is going to be outputted on the audio transmitter
Thanks for the suggestion @David_DeWitt. I’ve passed this onto our dev team for consideration.
Thank you so much!
I was thinking about a test tone for calculating the delay between command in→ audio out using the built in microphone.
Obviously is considering the use of the Bluetooth of the device that the app is running on (Mac/iphone/win/android ecc) for sending audio data.
Another thing to consider is keeping in sync analog audio for monitor and headphones, and also instructions sent from midi devices.
You’re welcome @David_DeWitt
